AH_AK
May 02, 2021Explorer
Ugh wet wood in Bigfoot
I recently bought a 2003 Bigfoot 10.5. The interior is in excellent condition. Seems to have barely been used. Generator has 30 hours on it. I paid the local Bigfoot dealer to inspect it before I bought it. No mention of water damage. So I get it home and start cleaning it and getting into all the nooks and crannies (like I should have done before buying) and I find some problems on the back wall. The trim below the basement back hatch is rotted but dry (previous leak). The wood seems to still have some integrity. There is a small hole in the shell which I assumed was caused by the fold up steps banging the wall while driving, but now I am thinking it may have been punched on purpose as a drain. So I go to the battery compartment and feel the back wall. Squishy. Worse, this is where the jack is mounted. I poke through the vinyl covering and the wood is an oatmeal consistency and still wet. It rained the other day and it was previously stored indoors, so I am thinking I have an active leak on that back wall. Could be the jack mount, or the window, or any number of other penetrations on that wall. I feel overwhelmed at the moment, but it seems like this can be fixed without gutting the whole camper.
Here is what I am thinking:
1. Take off the jack (I have it up on stands at the moment). Take off the mounting plate and see if I can tell which screws are in bad wood.
2. If rot extends up into generator compartment. Remove the generator otherwise just remove the batteries.
3. Rip out all the rotten wood and replace with good wood.
4. Remove and reseal all perforations on the back wall. Should I do this first? My thinking is that this might help me narrow down the source and thus the likely extent of the damage.
Best case scenario is that the seal on the jack plate is the source and I have found the worst of it. Guess my “awesome find” for a first truck camper was not so awesome.
Would love to hear from anyone that has had a similar problem and remediated it .
