Hemling
Jul 28, 2021Explorer
Ultimate payload monster?
What do you think is the top payload rating among new one-ton trucks? All the advertising goes toward horsepower/torque and towing capacity, but what configuration is king of payload?
Cummins12V98 wrote:
No one is going to respond directly to my question of how my SAE rear axle rating plus unloaded front axle weight is 1.000# over my 14k GVWR???
I ain't much smarter than a box of rocks, but I would guess there might be other components that limit GWR?
BTW, I don't think I have ever seen a weight tag where the total of axle weights is not greater than GVWR
rhagfo wrote:blt2ski wrote:rjstractor wrote:Cummins12V98 wrote:
GVWR is a JOKE!!! Someone please tell me how I can stay at or under 14k when my RAWR is 9,750# and my unloaded front axle weight is 5,250# when they add up to 15k. My solution is to have tonnage enough to cover my 6 tires load.
Even worse with my 2000 F250 diesel, to get to its 6100 lb or so RGAWR without exceeding its 8800 GVWR, I would have to pile all the weight behind the rear axle to unload the front axle from its 4500 lb or so empty weight to under 2800 pounds. Far safer to load the truck at 5500 on the rear, 4500 on the front even though at those weights I'm exceeding the GVWR by 1200 lbs.
Nothing "ILLEGAL" about either of these options. Reality per federal bridge laws, Cummins can go to 32k gvw, 20k on rear 12k or so on FA before being over the FBL standards.
RJ can hit 10-12k on his two axles ALSO before being over wieght per FBLs.
There are other issues that will get them off the road... Wieght will not be an issue, assuming they have the correct paid for tonnage.
Just like I've been pulled over multiple times, been thru DOT scale house upwards of 26000 gvw, I have yet to get an overweight ticket. Even tho door jam tag says gvwr is 18200. By the way, door tag sticker is in OM in my office.
A lot of what others have implied are correct if your going after manufacture warranty performance ratings. Add more options, get a heavier engine, tranny, dual alternators, AC, power windows etc, ALL take away payload, assuming FA and RA have the same numbers. Ext cab also heavier than regular, crew is heaviest yet.
Choose poison, hope it works for you, how you want to use it......
Marty
I find it interesting that a moderator would say that federal bridge laws make it legal to exceed the listed axle and tire ratings on truck.
Once you exceed GVWR you hit a grey area. While axle and tire may be considered legal to some, a lawyer will go after the statement in owners manuals that is is unsafe to exceed any of the weight numbers on the VIN tag.
Grit dog wrote:ktmrfs wrote:
thanks for the detailed info. So it looks like GM moved the 2500 to class 3 since at least with the duramax GVWR is 11,400 ish, pretty much limited by tires/axles as SRW.
Ford did this too. Idk if Dodge has yet or not. Don't actually care what the gvwr of any light duty truck is, because I know what numbers are true and what numbers are false. class rating is like using tire ply terminology. It's general, not specific.
But ya know what?
NOTHING CHANGED, save for maybe some heavier springs, but I'd doubt that even. IDK what changed in vehicle class regs to allow this, but it sure is fun hearing all the weight ninnies blather about how it's "unsafe" to go over 10k on a 3/4 ton and now, BAM! the OEMs have dun done it!
BTW, I don't think I have ever seen a weight tag where the total of axle weights is not greater than GVWR.
blt2ski wrote:
Ktmrfs
Class 1 is 0-6000 lbs
Class 2a is 6001-8400. Basically an HD class 1.
Class2b 8401-10000 lbs.
Class 3 10,001-14000? Possibly 13500 or 14500. Having a brain fart at the moment.
1 and 2b a generally speaking half ton/15 series trucks. Need to meet stricter emissions, mpg stats etc.
2b/3 trucks have a different emissions, don't need to meet at this time mpg specs.....
Class 4-8 up to 33000 are medium duty, 33k up are typically class 8. Tandem rear axle trucks. There are a few 7s depending upon spec that can legally get to 40,0000 gvwr.
Marty
Cummins12V98 wrote:CA Traveler wrote:
GVWR isn't just about dead weight. Consider suspension, brakes, stopping distant, stability when turning/swerving, weather, road conditions etc. Maybe other factors like mfg libiality etc.
GVWR is all about licensing and keeping it in a certain weight class.
