Hemling
Jul 28, 2021Explorer
Ultimate payload monster?
What do you think is the top payload rating among new one-ton trucks? All the advertising goes toward horsepower/torque and towing capacity, but what configuration is king of payload?
Cummins12V98 wrote:
No one is going to respond directly to my question of how my SAE rear axle rating plus unloaded front axle weight is 1.000# over my 14k GVWR???
Cummins12V98 wrote:CA Traveler wrote:
GVWR isn't just about dead weight. Consider suspension, brakes, stopping distant, stability when turning/swerving, weather, road conditions etc. Maybe other factors like mfg libiality etc.
GVWR is all about licensing and keeping it in a certain weight class.
blt2ski wrote:rjstractor wrote:Cummins12V98 wrote:
GVWR is a JOKE!!! Someone please tell me how I can stay at or under 14k when my RAWR is 9,750# and my unloaded front axle weight is 5,250# when they add up to 15k. My solution is to have tonnage enough to cover my 6 tires load.
Even worse with my 2000 F250 diesel, to get to its 6100 lb or so RGAWR without exceeding its 8800 GVWR, I would have to pile all the weight behind the rear axle to unload the front axle from its 4500 lb or so empty weight to under 2800 pounds. Far safer to load the truck at 5500 on the rear, 4500 on the front even though at those weights I'm exceeding the GVWR by 1200 lbs.
Nothing "ILLEGAL" about either of these options. Reality per federal bridge laws, Cummins can go to 32k gvw, 20k on rear 12k or so on FA before being over the FBL standards.
RJ can hit 10-12k on his two axles ALSO before being over wieght per FBLs.
There are other issues that will get them off the road... Wieght will not be an issue, assuming they have the correct paid for tonnage.
Just like I've been pulled over multiple times, been thru DOT scale house upwards of 26000 gvw, I have yet to get an overweight ticket. Even tho door jam tag says gvwr is 18200. By the way, door tag sticker is in OM in my office.
A lot of what others have implied are correct if your going after manufacture warranty performance ratings. Add more options, get a heavier engine, tranny, dual alternators, AC, power windows etc, ALL take away payload, assuming FA and RA have the same numbers. Ext cab also heavier than regular, crew is heaviest yet.
Choose poison, hope it works for you, how you want to use it......
Marty
Meh….
Easier to consider learning how to drive than worrying about all that fodder!
