Hemling
Jul 27, 2021Explorer
Ultimate payload monster?
What do you think is the top payload rating among new one-ton trucks? All the advertising goes toward horsepower/torque and towing capacity, but what configuration is king of payload?
rjstractor wrote:Cummins12V98 wrote:
GVWR is a JOKE!!! Someone please tell me how I can stay at or under 14k when my RAWR is 9,750# and my unloaded front axle weight is 5,250# when they add up to 15k. My solution is to have tonnage enough to cover my 6 tires load.
Even worse with my 2000 F250 diesel, to get to its 6100 lb or so RGAWR without exceeding its 8800 GVWR, I would have to pile all the weight behind the rear axle to unload the front axle from its 4500 lb or so empty weight to under 2800 pounds. Far safer to load the truck at 5500 on the rear, 4500 on the front even though at those weights I'm exceeding the GVWR by 1200 lbs.
