wanderingaimles
Aug 05, 2021Explorer
With empty weights starting at 12,000 lbs and GVWR starting at 16,000, You wont be pulling this with your Tesla, not even with the mythical Cybertruck.
And at a 16000 lb tow weight, tongue will start on the little one in 3/4 ton ranges at 1600 - 2000 lbs.
The amount of solar and storage would make it possible to run AC off the batteries, for at least a limited period, but it appears they put a standard 15k btuh unit on the roof, seems silly they didn't use a high efficiency SEER 18 mini split to conserve energy.
Tank sizes seem good, but I wonder if getting the optional battery upgrade cost you tank capacity due to either weight, or underbelly space.
Either way, this looks like a great bragging piece for those with more Dollars than Sense.
