profdant139 wrote:
Whatever trailer you get, make sure that your vehicle can safely stop the trailer without overheating the brakes, especially in hilly country. A van will have no trouble pulling a trailer. But the braking is a different issue.
Talk about a wrong concept that just won't die. I can't count how many times this misinformation gets posted, here and all over the place. If you are relying on ANY tow vehicle to provide braking duties for any trailer over a very modest weight (1500lbs in many states) you are not only breaking the law, you are exceeding the capacities of the tow vehicle, and you are endangering yourself and others. That's not much of a problem, however, since the trailer is equipped with it's own brakes, and stops itself, assuming that the operator is smart enough to use a properly functioning brake controller.
Posts, numbering in the hundreds over the years here, have all made the same ridiculous claim. " Well you might be able to pull the thing, but can you stop it with those obviously inadequate brakes on your ( pick one...... SUV, van, pick-up, etc....) Unbelievable.
