jdkd123 wrote:
Too many panic replys here. Mid 20's overnight for a few hours, with a heated interior will not be a problem. Your black tank is not going to freeze either. At most I might disconnect a water hose and drain that. Use your own water for overnight. Jmo from a cold weather new england camper.
A cold-weather Virginia camper agrees. We just did a New Year's trip and had upper 20s a few nights. We used the on-board tank (no water hook ups) and two space heaters. I did put a 60W trouble light in the bay with the water filter, just to make DW feel better.
As said before, as long as the majority of the time temps are above freezing, you'll have no problems.
Teach
