Me_Again
Sep 01, 2022Explorer III
blt2ski wrote:
Mkirsh,
Thank you
I think I'm going to find something similar if I follow links in RCW46 re single axle unladen trailers under 2000 lbs. But max gvw will be 4500 per my memory last I looked, or 3000 per e-trailer link Chris gave a page or two ago. With like Canadian laws, 40% max of TV vehicle down to a minimum of 1000 lbs of trailer gvw.
As I understand it, a mini Cooper with a 4k gvw, would get a max unbraked at 1600 lbs, over that they need brakes! Tealboy's situation, at 2600 trailer gvw, SUV at 6000, has max unbraked at 2400, his trailer would require brakes here in WA st.even if trailer is less than 2000 tare. If tealboy's trailer is over 2000 tare, he requires brakes no matter his trailers gvw. Chris is in same issue towing his sand buggy with explorer, but probably legal unbraked with F150. As that trailer probably wieghs 500 lbs plus or minus 100 lbs. I'm swag'ing Chris's trailer at 2500-2800 loaded with sand buggy.
I need to follow links to the other parts of my states "Revised Codes of Washington" RCW laws to get a better reference.
I would like to believe, anyone following this, should be getting a better reference point as to when brakes are required for Single Axle trailers, vs not, vs when common sense says have brakes on the trailer.
Marty
The Primo 6x12 trailer has a manufacturer's weight of 700 lbs. KRX SxS is heavy, trailer loaded weight is 3080. Aluminum F150 only weighs 300 more than Edge ST. The Edge ST with the twin turbo 2.7L V6 and Ford Performance suspension handled the trailer very well with the Can Am Spyder at around 22-2300 lbs.
