sam22Explorer IIIFeb 22, 2015Under 2000lbsHello! This is my first post here so hopefully I haven't put this is the wrong spot or asked a question that's been answered a thousand times! Anyways, my situation is that I want to buy a Jeep Patr...Show More
rbpruExplorer IIFeb 22, 2015You have boxed yourself into a corner.The tow vehicle, floor plan and cost all are interrelated. Each depends on the other.If you pick one you have picked the others. Often the floor plan and size are the start point, then the tow vehicle and then you see what it costs for what you want.If you are set on the TV you have selected what you can pull.My guess would be a pop-up.
Related ContentAnyone switched from blue ox 1500 to 2000lb bars?Outlaw /Funmover A or C? (8' x 5', 2000lbs in garage??)Re: Hard sided campers under 1500lbs with 6' int ht spreadsheet.Here's a list of stand up hard sided campers under 1400lbs.Re: Load range E--ST Tire
