You_can_t_take_
Jun 30, 2013Explorer
firemedic1169 wrote:skipnchar wrote:I'm beginning to think that this would be my easiest solution. I know exactly where I need to look and I can probably make due with a 1ft by 1ft hole then patch it back up.
I"ve seen the coroplast stapled, glued and screwed in place. If you know where you need to get to it may be easier to cut a working hole and piece the part you take out together again with Eternabond tape.
Cut the hole on three sides only and use the 'front' side as a folded 'hinge'. That way when you tape it back up... even if the tape lets go you will have a 'flap' that tends to close while driving. It will also be easier to tape up since the cuts will line up and you can't lose it on the highway. Been there... done that.
