ol__yeller
Jul 01, 2013Explorer II
Water leaks seek out the lowest point to drain. The actual leak could be a long ways from where the water comes out. You may have to pressurize the system until it leaks and follow the water trail. Or if it is a drain, fill the tank. I'd also try both city and tank water systems. If you still have no source, then your problem is from the weather leaking to the inside. One other suggestion would be that the AC condensate is leaking inside but I'd think that would be apparent on the ceiling. Good luck!
