firemedic1169
Jul 01, 2013Explorer
ol' yeller wrote:Made an appointment today but they can't get me in until the 17th. put a fan on the wet spot to dry it out and with all the rain we have been getting this should tell me if its coming from the outside or if its from the water pipes as I'm not hooked up to water right now. There are no water marks on the ceiling so I don't think its the AC.
Water leaks seek out the lowest point to drain. The actual leak could be a long ways from where the water comes out. You may have to pressurize the system until it leaks and follow the water trail. Or if it is a drain, fill the tank. I'd also try both city and tank water systems. If you still have no source, then your problem is from the weather leaking to the inside. One other suggestion would be that the AC condensate is leaking inside but I'd think that would be apparent on the ceiling. Good luck!
