jerryleejr's avatar
jerryleejr
Understanding COG
Ok,
I understand you want the COG of the TC to be centered on or slightly forward of the rear axle. My question is a lot of manufactures list the CG of the camper or provide a sticker showing its location. But where do you take the measurement on your truck? From the rear wall of the cab to rear axle? Or a point in space calculated by arm and moment to the rear axle? On the off chance it ends up slightly behind the rear axle can you add weight to the front to offset? There was a post that calculated 18ish lbs per inch aft of the axle. Just trying to get an idea without physically having the truck and TC to check.
JJ
