3_tons
Nov 16, 2021Explorer III
I think you may be over-thinking it a bit…JMO
You didn’t mention whether or not you have a onboard genny?…
If not:
Since the Victron has it’s own built-in ATS switch (priority, shore or gen power), consider simply re-routing your shore power cord to the Victron, then from the Victron to the Main panel…
If so: Re-route the Shore power / Genny ATS output from the main panel to the Victron (and complete as mentioned above)…
Having said that, with an inverter you may also want to consider adding a sub-panel so that the inverter cannot inadvertently power up the OEM converter-charger (resulting in a’round-robin’ affair…), refer (passive power sensing-switching), water heater (or say, other wasteful consumers) etc…
Feel free to PM me for more ideas
3 tons
If not:
3 tons
44,072 PostsLatest Activity: Aug 16, 2026
