The_Kunkels's avatar
The_Kunkels
Uneven slidout
While looking at the tt we may buy from the cg we are renting I noticed the slide-out is about 2" lower on one end than the other. Is there an adjustment or is there a more serious problem. It is a 2001 Hornet Sport. Thanks.
  • Down the road.
    Thanks for the slide manual info.
    Mine is bout two inches high on one end when it I retracted. It is level on the outside. I will give it a look see.
    We bought the TT used and have used it extensively for the past three years. I just wrote it off to the high quality craftsmanship one finds in modern TTs. :)
    Maybe it is that way so they could get the slide to work, before it left the factory.
  • I was told with mine when I'm running my slide in or out they told me to continue to hold the button on even after i thought it was all the way in or all the way out. In doing that you will hear the motor kick out on its own. That will keep both of your slide motors pulling equally, (Basically synchronizing your slide motors)
