boogie_4wheel wrote:
To do a good job; disconnect the driveshaft and rotate the joint with your hand. Feel for stiff and/or rough movement which would indicate dry and possibly failed needle bearings. Doing this takes more time but you will find a bad joint much earlier.
If you have a two piece rear shaft, a failing center joint can cause premature carrier bearing failure (destroying the rubber support).
Climbing under the truck and twisting and shaking the shaft looking for movement will only show you an already destroyed joint. Shudder during launch because of a bad joint will likely go unnoticed when shaking the shaft by hand and looking for movement.
I just rebuilt the double cardan on the front of my dodge yesterday. Stock joints. They were still greased good, but the inside of the caps were getting dirty; 126k miles. Your joints could be fine still
As stated above... this is the only way to check u-joints, a seized u-joint is hard, almost impossible to diagnose without removal of the drive shaft.
