Tonyandkaren writes
“Nice job on the trailer rebuild Gdetrailer!”
Thank You!
It was a lot of work but in the end well worth it since it is customized to OUR needs and tastes, something like ours will most likely not be something others will want..
“Your experiences with factory built trailers shows why some people such as Darla chose to build using a cargo trailer. No doubt her trailer will weigh more and be expensive but she's getting a very solid, practically leak proof base to finish out exactly as she wants it “
While my rebuild does show typical RV "weaknesses" keep in mind I was operating on a 25 year RV which had been EXTREMELY NEGLECTED. It spent 15+ yrs sitting in a RV park and the owners failed to do needed routine maintenance like checking and replacing caulking.
While a lot of folks will think cargo trailers are “better” and do not leak that is further from the truth.
Case in point..
HEREUnder service they state they fix..
“Roof and exterior leak repairs” as one of the "services" they do..
Even Semi trailers leak (the construction is typically the same as cargo trailers)
This is one example of a roofing material developed for leaking Semi trailer roofs..
SEMI ROOF COATINGSHere is a post of someone with a cargo trailer roof leak..
LEAKY CARGO TRAILER LINKYet another leak..
HEREThere are some critical inherent issues that must be dealt with properly or Darla’s build is going to end up being a wet moldy mess.
Cargo trailers due to the nature of their design will have thousands of rivets holding the outside aluminum skin on, all it takes is one rivet being slightly loose or the caulking cracking and it is no longer a water proof method.
Cargo trailers typically use 4x8 ft sheets of aluminum for sidewalls and even the roof, this leads to another problem.. Water proofing the joints..
A sealant could be applied during construction at the joints but after it has been a few years that sealant now becomes an incessant and continual source of hidden leaks..
Once the sealant starts breaking down you will have random leaks which are going to drive you crazy and fixing them properly would require drilling out rivets and lifting the joint to reapply sealant..
Then there is the roof to sidewall and sidewall corner connections… Yep, same problem…
Additionally there is a massive issue with sweating or condensation inside, this needs to be dealt with before the interior walls are put in place..
The aluminum skin and studs if the outside is cold will gather and condense moisture from the warm air inside. Pretty much creating a rain storm inside. I have a garage with a all metal roof and even with good insulation under certain weather conditions I get one heck of a rain storm inside the garage..
Metal wall studs create an additional problem.. No thermal break, yep, those wall studs if you mount your inside paneling will suck the heat out in the winter and in the summer will turn the trailer into an oven.. You have to create a thermal break by using wall studs which are not thermally conductive over top the metal studs or you have to install extra metal studs which do not touch the exterior studs or wall material.
Cargo trailers typically do not have any seals at the doors, this allows for natural air movement exchanging inside air for outside air reducing the possible condensation from being a huge problem.
Darla will need to make the cargo trailer nearly air tight if she wants to reasonably heat and cool the trailer.. She does not have windows for allowing cross ventilation nor any roof vents..
She picked too large of a A/C unit which will not be effective for reducing the moisture so she most likely will need to buy a dehumidifier and run that in conjunction with the A/C unit. This will add unneeded cost, wasted space and not to mention LESS reliability (I use a dehumidifier in my home basement and I average two years out of a dehumidifier at $275 each).
“. It's not something the majority of RVs would want but from reading her blog and the posts on this thread, I'm believe that she's going to be living in the trailer fulltime for years with no intention of selling it. I certainly don't agree with all of her ideas but I'm very interested in seeing the finished product and how she likes it after a few months or years of living in it. “It will be interesting to say the least.
But over time Darla WILL run into a lot of the same leak issues that RVs get but unlike a RV will not be as easy to detect OR repair.
“Obviously we all have different wants and needs-just look at how many different types of RVs are manufactured. But what Darla wants isn't being made so custom is a good way to get it. I'm not sure where all of the animosity on this thread is coming from. It doesn't make sense to me to get angry about something that doesn't affect you. :-) “
There is nothing wrong with a custom build, but if you want it to work correctly and not have to do over several times it is best to do it “right” out of the starting gate. Part of getting it right is to stop and pause a moment with a open mind and be willing to adjust your design as others point out short comings
(after all.. Darla DID ASK FOR HELP).
As in anything we do, it is ALL about compromise, there are things that just can not be helped and must be changed in order to make the entire project work.. It is called compromise.
Often our “plans” look good on paper but when they are being built you find things which just don’t work as you expected. This often creates very expensive changes and if the plan progressed to far it may not be changeable.
When others with experience tell you something in the design isn’t right or won’t work as designed you better stop and rethink your design..
There ARE a lot of things Darla has designed which from my own experiences I know are not going to work as well as expected but alas pretty much anything that has been posted stating so has fallen on deaf ears.. You just can’t teach others with closed minds, kind of reminds me of parenting kids (have a 14yr old “teen” right now that “knows” more than us parents)..
