path1
Jun 02, 2014Explorer
LittleBill wrote:path1 wrote:wnjj wrote:LittleBill wrote:
i understand that, i thought it would ruin the wrench otherwise why have the comment? and i have seen it alot
I think they don't want you using it as a breaker bar and exceeding its capabilities. When breaking bolts loose people usually apply as much pressure as needed, not just a limited torque.
ON the "clicker" type, at least mine says don't use (or can't use) to undo stuff. That is partially why I also have the old style "pointer". To see what torque was, as in past tense.
yep all i use is a clicker type, that said it has a ratchet head and can be locked both ways LOL
"that said it has a ratchet head and can be locked both ways LOL" True. Reason I used old style was because I wanted to see what torque (or how loose) old plugs were before changing them out, so that I could adjust maint schedule of when I did them next.
44,056 PostsLatest Activity: Jan 12, 2020
