73guna's avatar
73guna
*UPDATE*Calling Duramax owners 1st trip with camper bad fuel mileage
I have a 2007 crew cab Duramax LBZ 4 wheel drive.
We recently got back from our first camping trip with our new Wildwood 31qbts. The trailer weighs in dry at approximately 8500 pounds. Loaded down I estimated the weight to be right close to 10,000 pounds.
My mileage on the trip was anywhere from 6.5 to 7.5 miles per gallon.
Fresh oil change with synthetic right before trip, tires aired up to 80 pounds, new fuel filter.
Cruise was set between 65 and 70 miles per hour on the flat in the hills I pedaled it. We had a pretty good crosswind all the way down to our campsite and a little ways back. Once the wind stopped I check my fuel mileage again and it was still within the same range.
On the trip I did have a check engine light come on which was p0401 which indicates low flow in the EGR valve. The same code came up prior to the trip and I remove the EGR valve and cooler and clean them.
Now, before I go on to the Duramax forums and have all the Young Guns tell me to delete the EGR and step up to EFI live programming I would like to get to the bottom of this and figure out what is causing my poor fuel economy.
Just wondering if anyone else has ever dealt with poor fuel economy and what you did to resolve the issue.
If it's something I can check on my own that would be great before I took it to a dealer have a scanner hooked to it.
  • I'm well aware of that. I varied my speed and check the mileage even when there was no wind. It never changed.
    6.5 miles per gallon I would expect going 80 miles an hour up and down the hills.
    I think there's more to it than just slowing down.
  • Slow down! Fuel economy is greatly effected by load, speed, and head wind. Were, or are you looking at the lie o meter or hand calculating? Also guessing weights is plane crazy. Stop at a set of scales and get real weight numbers.
