please explain these rim ratings.. same load rating but different Psi ratings…
Wheel Size 15 x 6 in - Bolt Pattern 5 on 5 in - Load Rating 2,600 lb. - PSI 60 lb.
Wheel Size 15 x 6 in - Bolt Pattern 5 on 4.50 in - Load Rating 2,600 lb. - PSI 80 lb.
Then these rim ratings… different load ratings, same Psi ratings…
Wheel Size 15 x 6 in - Bolt Pattern 6 on 5.50 in - Load Rating 2,600 lb. - PSI 60 lb.
Wheel Size 15 x 6 in - Bolt Pattern 6 on 5.50 in - Load Rating 2,850 lb. - PSI 60 lb.
All are steel trailer wheels, all are 15x6, two 5 bolt and two 6 bolt, all from the same supplier, all have a zero offset, three have the same 2600 pound load rating one of those rated for a LR E and two are rated for LR C… the one rated for a LR E tire is only 5 bolt and has a smaller bolt circle…
explain why they are rated at all if you can use any tire you desire...
