Hardscrabble's avatar
Hardscrabble
Upgrade truck suspension
Hi all,
Just on the shakedown trip with the new rig, a NL 8-11 and a 2019 Chevy 3500HD Duramax. Over all I am happy with most of the handling, certainly the acceleration and pulling power is fine. We do have StableLoads (upper) installed. I am seeing that I don't like the "hobby horse" bouncing when we hit uneven pavement, expansion joints and the like. It seems in searching the many threads that even though the truck is brand new that the front shocks are most likely the issue, that replacing the front shocks with Rancho 9000s might be my best result. I just want to confirm my thoughts here. The truck sits about level.
Any thoughts?
Regards, Tom
  • The Bilstein 5100 is a good replacement also. It is slightly firmer than stock.
  • If your going to change the shocks, go with Bilstein 4600’s, no shock adjustments required.
  • Rancho 9000’s made a huge improvement on our overall ride especially over those nasty bridge joints! Helped a lot with the unloaded ride as well. With the front set on 4 and the rear on 1 the empty ride wasn’t bad
    Bob
    P.S. Congratulations on the new rig!
  • I’d try adjusting the air pressure in the front because it’s free, and then go for shocks if needed.
