Huntindog
Oct 23, 2019Explorer
Twistedlarch wrote:Are those actual scaled weights loaded for a trip that you had done? Or the advertised brochure weights?
Hi all, I just upgraded from a Tacoma to a Tundra. My 21' TT weighs in at 3,725 lbs with a tongue weight of 410 lbs. It squatted my Tacoma pretty good but doesn't seem to phase the Tundra much.
My question is...Do I still need to use the weight distribution hitch?
I found a standard stinger that will also support the anti-sway system and the Tundra has the integrated brake controller with anti-sway built in, will this work or should I still use the WDH?
Thanks!
Brian
