ST205/75-14 C at 1760 lbs = 7040 lb capacity. I'd bet your 7700 lbs is a estimate and not a actual scaled weight.
Looks like the 205/75 tires are close to being maxed out.
Your choice on going with a 14" load D which would give tires on the trailer a bit more needed reserve capacity. Now you don't want to get silly and go with 2800-3000 lb + rated tires on a 7k lb road trailer .
For my use having several cargo trailers used as job site tool trailers/boat trailers that came with 14" tires ...I sold the 14" tires and wheels then moved up to 15" sizes.
The cargo trailers were pulled over rough roads getting to worksites so taller tires made things ride a bit easier inside the trailer.
