buzter's avatar
buzter
Upper Fridge vent blocked off...Why?
I recently purchased a 2013 Sprinter 316bik. It has a slide in the kitchen so the fridge is vented at the bottom (typical) and then it is vented thru the sidewall at the top, not thru the roof as it is on the slide. I took the cover off last night and there is a piece of tin mounted on the inside covering half the vent. Wondering why this is, it looks to be factory mounted as it is screwed in from the inside. Wouldn't it be better if vent was wide open?? Thanks for all input.
