time2roll
Mar 28, 2017Nomad
I would return the cooler and stick with OEM. Partially because IMO any additional fittings or rubber hoses present additional risk of leaking. As long as you have the OEM cooler with steel lines and flare fittings I would not bust into it.
If concerned about the transmission consider a fluid exchange with synthetic fluid if you have standard fluid in now that has some miles on it.
