Terryallan
Apr 02, 2017Explorer II
RPreeb wrote:Terryallan wrote:
Nope you don't need it. And to be honest. You want the transmission running at temp. Too cool can be a problem. could keep the trany from changing gears correctly. They change differently before they warm up, at least mine does. Won't go into OD before it warms up.
That seems a bit off to me. I hit the highway within 5 blocks of leaving the garage, and my Ecoboost F-150 shifts to 6th gear as soon as I pass about 55 or 60, as long as I'm not accelerating hard. The transmission temp gauge hasn't even started to move yet (even the engine temp hasn't started to register).
For the OP, if you already have one, then I doubt that adding a second one would be necessary.
that is the way it was designed. would not drop into OD before the trany reached operating temp. You can argue with Ford. but it worked perfectly for 13 years.
As for the cooler. Some have suggested putting one inline BEFORE the radiator. WHY? The fluid will be the same temp as the engine coolant when it comes out of the radiator, no matter how many coolers are installed before the radiator. Transmission cooler only work when they are AFTER the radiator.
