fjrjohnny wrote:
About 3/4 to 1".
? Betweeen the top and bottom brackets? I have airlifts-I dont recall actual number needed just to install the bags, more like 7" or 9"? Im pretty sure with no air the distance would still be considerably more than an 1", . Something doesnt sound right, I would think with less weight you need less air- but unless your inflated distance is different than mine thats a lot of compression.
I run 80-85psi loaded 5-10psi empty, overloads only come into play if Im way off camber or huge hit to suspension.
