Cummins12V98 wrote:
FishOnOne wrote:
Cummins12V98 wrote:
4x4ord wrote:
Cummins12V98 wrote:
They also powered the F650/750 until a couple years ago with an Allison 3000 behind it. Lots of Freightliner MD's.
Why would Ford switch from an almighty Cummins to a light duty engine to power their F650/750 trucks......unbelievable:?
I think FISH got tired of me pointing that out and got someone at Ford to make the change!
The reason for the change is:
6.7 Cummins B10 rating is 250k miles
6.7 Power Stroke B10 rating is >500k miles. Also the Power Stroke has a 5 year 250k mile powertrain warranty.
I know which engine I want in my medium duty application. :B
And the commercial industry is loving the new Ford medium duty trucks since they can simple take their truck to any Ford dealer and have the truck serviced or repaired and from I'm hearing the new factory is backlogged into the unforeseeable future. Hence the reason GM is jumping back into the medium duty truck industry.
As usual Fish does not fill in ALL the blanks.
6.7L CUMMINS SPECS
Production Years:
2007.5 - current
Configuration:
Inline 6 cylinder
B10 Life:
250,000 miles (~400,000 km)
B50 Life:
350,000 miles (~560,000 km)
Displacement:
408 cubic inches, 6.7 liters
Bore x Stroke:
4.21" x 4.88"
Cylinder Head Material:
Cast iron
Engine Block Material:
Cast iron
Firing Order:
1-5-3-6-2-4
Compression Ratio:
17.3 : 1
Injection:
Direct injection, electronically controlled Bosch high pressure common rail, 26,000 psi maximum injection pressure
Aspiration:
Holset HE351VE variable geometry turbocharger (VGT), integrated exhaust brake function, air-to-air intercooler (charge air cooler)
Valvetrain:
OHV, 4 valves per cylinder, solid lifter camshaft
Weight:
1050-1150 lbs dry
Oil Capacity:
12 qts w/ filter
Fuel:
2007 - 2013 models are B5 Biodiesel compatible, 2013.5+ models are B20 biodiesel compatible, ULSD only
Governed Speed:
• 3,013 rpm (2007 - 2012)
• 3,000 rpm (2013+)
Horsepower:
350 - 385 hp, see chart below
Torque:
610 - 900 lb-ft, see chart below
Dimensions:
Length
Width
Height
41.7"
28.6"
37.8"
No.... My answer was clear and concise to your erralavent post. In additionYou just posted more errelavent garbage as usual
