Spade_Cooley's avatar
Spade_Cooley
Using an electric impact wrench to raise jacks?
I heard somewhere that an electric impact wrench works well for raising and lowering trailer jacks. I used an electric drill until it gave up and now I'm using the crank that came with the trailer. Sears has the impact wrench on sale for $119 and I'm thinking about it. Anyone else tried this method?
  • We still use our 18 volt power drill and it does a great job as long as I clean and dry lube jacks a couple times a year. Been thinking of upgrading to a lithium ion power drill and have seen where the set includes and impact driver which I believe would prove to be better suited for this task.
  • Assuming you are refering to the stabilizers - You don't need an impact wrench. I use my battery powered drill to do this. You might have to adjust the tourque, or give it a twist manually to get going, but the impact is overkill.
    Why did you give up on the electric drill? Mine is a Craftsman.
  • I have not used this technique yet but am seriously thinking about it. Been to many a CG and people around me have used impacts or drills and they seem to work very well.
