mutt48's avatar
mutt48
using BAL levelers
We have a Keystone Bullet Premier (22RBPR) that has a dry weight on 4650 lbs. I have one BAL 28050 leveler (from prior popup trailer days) and was wondering if anyone is using two BALs on a dual axel TT? I have tried to find out the weight limit on the BAL 28050 but specs are not listed on line that I could see. I have plenty of space between the two tires (about 20") so that is not an issue.
Also....anyone using the Camco 44753 tri leveler?? Looks interesting and had pretty good product reviews. I'm wondering about ease of use and how to chock tires when they're up on a higher level???
  • mutt48 wrote:
    Nvr2loud wrote:
    First off... you are going to have a whole lot of people flame you for calling them levelers, be prepared for that LOL
    Secondly... I use 6 of the scissor jack stabilizers on my trailer. Two of them are BAL and the other 4 are Husky.
    I use two at the front corners, a pair just in front of the front axle, and a pair just behind the rear axle. That allows me to lift to stabilize and fine-tune level. Do not lift the trailer very far behind the rear axle, you will not like the results.
    How and where did you mount the Huskys?? To the frame, axels,???
    I mounted them to the frame within 6 inches of the axle mount reinforcement plates with nuts and bolts, the supplied self-tapping screws are not great for this application.
  • First off... you are going to have a whole lot of people flame you for calling them levelers, be prepared for that LOL
