soos's avatar
soos
Explorer II
Feb 07, 2014
Using camper when not on truck
Not sure if I imagined this but I think someone said that the Lance owners manual says that we should Not use the camper when it's not on the truck?
Is that true?
Does it make sense, or do people ignore it and do it anyway?
Thanks
  • I've used mine when not on the truck many, many times. I usually lower the camper as low to the ground as possible simply to make it more sturdy. I've also used it when raised to truck level with out issue it just wobbles around a bit.
