SoundGuy
May 15, 2015Explorer
RJCorazza wrote:
Since you will be moving it anyway (to the fairly level spot) why not take the trailer to a level residential street and weigh it?
I weigh mine on a level stretch, at seated ball height (exactly level or not).
That's what I do as well, not to just weigh the tongue but whenever I might be setting up a WD hitch ... take the trailer to a vacant area of a mall parking lot and set up wherever I can find a relatively flat, level area for the trailer to sit while I'm taking my measurements. It's been awhile now so I forget the exact numbers but I seem to recall my tongue weight measurements taken with the trailer leveled on our significantly sloped driveway were quite a bit different than the reading I got at the parking lot, IIRC something on the order of ~ 50 lbs. IMO that's quite a bit so if you're going to the trouble of measuring it with a Sherline I'd say it's worth dragging the trailer to a lot somewhere so you can measure with the trailer sitting on a flat, level surface.
