Aadkins101ExplorerJan 23, 2014Using Slides in Freezing WeatherI read somewhere that slides can be damaged if used in freezing temperatures. I need some clarification here! Thank you.
AirForceAnglerExplorerJan 23, 2014If there was moisture on it and the moving seal froze to the slide, the seal could be damaged.
Related Contentfreezing weatherCamping in sub freezing weatherFridge in freezing weatherFreezing WeatherFreezing weather prep
