jaycocreek
Jan 23, 2014Explorer II
I use the slide often in freezing temps and have learned that checking outside around the slide for ice is very important. I run heat in prior too running the slide, but ice sometimes builds up around the slide and seal from the pitched roof draining over the frozen drain rail.
I like to run my slide out about once a month.
44,070 PostsLatest Activity: Sep 18, 2026
