jmtandem
Jan 23, 2014Explorer II
I think the biggest issue most have is snow, ice, leaves, etc. on the top of the slide that can damage the rubber gasket when moving the slide in. There is a second issue in very cold weather in that making the coach slightly smaller by leaving the slide in uses less heat (a smaller space to heat albiet not much smaller and it might not make that much of a difference) if that is an issue with you.
44,070 PostsLatest Activity: Sep 18, 2026
