USAFBILL
Jan 23, 2014Explorer
If you live in a place with harsh winters, you’ve no doubt experienced the frustration of trying to force a frozen door open. Thankfully, there’s a simple solution that uses the magic of chemistry. Using ordinary cooking spray, coat all of the rubber gaskets on the inside of your door and then gently wipe with a paper towel. Doors freeze close because water settles in these gaskets and then hardens, so a quick coating of lipids will make their seal tighter and prevent any moisture from getting in. Guess this might apply to RV Slides also
44,070 PostsLatest Activity: Sep 18, 2026
