prginocx
Jan 21, 2015Explorer
Using the Cabover in Freezing weather
I have to remove the camper from the truck, and I will have 110VAC plug in available.
But I'm worried about my 12 gal tank of water freezing. I know the Daytime temps will be low 40s, but after about 5 pm it will be below 32 degrees for sure. Most of the time it gets down around 20 degrees at night, when I wake up its still 25 or so...
Will my water tank freeze ? What can I do ? What about my pump inside the camper and its attached water lines, I can't leave the water running, right ? I can run a electric radiant heater INSIDE the camper, but I like to sleep in the cold with a TON of blankets. Running the darn Propane furnace is too loud.
I don't think I will have water hookups, only 115VAC power.
My camper is a Pastime 8.5' model, 2009. I won't be using the toilet inside the camper. I do have an extra 5 gal tank of propane.
