AH64ID wrote:
Yeah, "dry" items only. I figured that would be the unspoken rule, but you know what they say about common sense.
It seems people have done it without issue, or wouldn't touch it with a 10 foot pole.... Kinda like towing with a 1/2 ton at max ratings :-)
Curious as to what you were planning to bake?
Pizza? Frozen types 20-25 minutes, tops, not worth the hassle to stop somewhere to put it in the oven then travel for 15-20 minutes then stop to check if done.. Waste more time stopping and starting than worth..
Bread, buns, rolls and such, once again they take very little bake time compared to prep time baking time 15-20 minutes and you would want to check or monitor them to make sure they don't burn.. Not to mention many breads or anything the rises typically will fall with a lot of bumps and you will end up with hard hockey pucks.
