jmacpolo wrote:
I started out years ago towing our 7,000 lb trailer with my old chevy 2500 with the 350. I tow mostly in the Sierra and Rocky Mts. I hated the way I had to slow down to 45 mph going up the grades. So after reading what others had said about them, I bought a 2007 Ford 3500 V-10. I have been very disappointed with the power of the V-10. Now I can hold 50-55 mph while going up grades. I thought the v-10 would give better performance than that. Am I expecting too much from this motor, or is there a problem with my V-10?
Thanks,
John
John, you have several problems.
#1. Pulling 14 thousands up a hill at 50 to 55 MPH is jamming! It really is pretty fast.
#2. If you don't wind that V10 up to 4,750 you're not making max HP and you need to make the most HP possible to make it up that hill faster. (The 572 CI engine I drive every other weekend I wind up to 7 grand on every shift so I think your little V10 will live just fine at 4,700 RPM.) (BTW, Ford says that, not just me.)
#3. I don't know where you pull but lets say you're going over Donner pass. You have about 360 HP to start with. By the time you get to the top of Donner pass you're down to about 280 HP. That's not a bunch when you're trying to pull 14K up a hill.
#4. HP takes fuel. Lots of HP takes lots of fuel. You want to go fast or get good mileage? Pick "one." Sorry, but you only get to pick one. 750 HP for me uses about 1.25 gallons of gasoline in about 10 seconds. Now you only have about half that HP but you get the drift of what kind of fuel you're going to burn if you want to make all of your HP and go fast up the hill.
#5. I don't have a HP chart for the V10 but if your winding that engine up to less than 4 grand you're "probably" making less than 300 HP. Couple that with altitude and now you're making somewhere around mid 200 HP.
Bottom line. You want to go fast up a hill. Plant your right foot to the floor and hold it there. The only bad thing that is going to happen is you're going to burn a lot of fuel. I can't help you with that. Remember the pick one I told you about earlier? :B
