jrichd
Dec 29, 2020Explorer
V6 Silverados
Can the new Chevy Silverados with the 4.3L V6 really how over 9000 pounds? Anyone with practical experience in one case to arrest to that?
I'm not sure where that number comes from, because with that engine the max towing is 7800 lbs. GCWR is 12,800, which sounds reasonable for the hp/torque of that motor. With a truck GVWR of 7000ish, a GCWR of 12,800 gives a realistic towing capacity of 6000 lbs or so. Interestingly, the 2.7 turbo 4 has a significantly higher towing capacity, and with its far superior low end torque would make a much better towing motor. If I were in the market for a GM 1500 series truck I would consider that motor even over the 5.3 V8.
