jrichd
Dec 29, 2020Explorer
V6 Silverados
Can the new Chevy Silverados with the 4.3L V6 really how over 9000 pounds? Anyone with practical experience in one case to arrest to that?
Lwiddis wrote:
I wouldn't consider a 4.3L and a 9000 pound trailer.
jrichd wrote:
I was going off the vin number lookup function in the camping world towing guide (https://rv.campingworld.com/towguide) For example, vin # 1GCRWBEH3MZ116570 is a 2021 Silverado 1500 Custom with the 4.3L V6. Enter that vin and it returns a tow limit of 9700. If you enter vin 1GCUYDED1MZ106911 which is a 2021 Silverado LT with the 5.3L V8, it returns 9000 or 9100 depending on bed length. Reason I'm asking is the price difference is HUGE.
wanderingaimlessly wrote:
Not a fair comparasion, you switched to a diesel.:E
I'm not sure where that number comes from, because with that engine the max towing is 7800 lbs. GCWR is 12,800, which sounds reasonable for the hp/torque of that motor. With a truck GVWR of 7000ish, a GCWR of 12,800 gives a realistic towing capacity of 6000 lbs or so. Interestingly, the 2.7 turbo 4 has a significantly higher towing capacity, and with its far superior low end torque would make a much better towing motor. If I were in the market for a GM 1500 series truck I would consider that motor even over the 5.3 V8.
