IAMICHABOD
Nov 09, 2014Explorer III
The last thing you want to do is put those flexible extenders on your valve stems. They have a tendency to leak and if they get loose from the anchoring point they can flop around and not only do damage to your wheel but suddenly deflate the tire.
What is needed is a extended valve stem that will let you quickly check your tire pressure. They add no extra weight like the Extenders would and balancing is no problem.
The best on the market is The Tire Man
Chuck is the original designer of these an he has been around for years. If you have any questions just give him a call, he is always happy to help.
I and a lot of others on the Class C forum have used them for years with no problems and we can check the pressure if our Duallys in minutes with ease.
44,066 PostsLatest Activity: May 13, 2026
