Community Alumni
Oct 31, 2016Not applicable
What I have found is that the vent system is often too small to offset the volume of water being pumped in thru the fresh tank fill. You end up with water coming back out the filler port and the vent hole.
When this happens I use my air compressor and force air thru both the vent and filler holes. This clears both lines and I can start filling again. I might have to do this a couple times when filling the tank.
Using lower pressure to fill the tank also helps.
44,071 PostsLatest Activity: Aug 30, 2026
