JWP127's avatar
JWP127
Venture Travel Trailers
Looking at a 2019 Venture SportTrek Touring Edition 322VRL Travel Trailer. Anyone have experience with these? I know no travel trailer is built great, but some are better / worse than others.
  • JWP127 wrote:
    Wow. What year, make and model did you buy?
    2011 KZ Spree 261RKS.
  • Lynnmor wrote:
    Venture is one of KZ's brands. Most of that company's axles, tires, frames and springs are the bare minimum and the carrying capacity shows that. You said that the CCC might not be a big deal, but my take on it is that it is of a marginal design. If you want strength, safety and durability, perhaps this is not the trailer you want. I bought a KZ trailer and so far I have welded the frame in four places, replaced the weak and bent axles, the broken springs, the wheel bearings and all the brake parts. When shopping for a trailer, start at the ground and work up, that pretty stuff is less important.
  • Venture is one of KZ's brands. Most of that company's axles, tires, frames and springs are the bare minimum and the carrying capacity shows that. You said that the CCC might not be a big deal, but my take on it is that it is of a marginal design. If you want strength, safety and durability, perhaps this is not the trailer you want. I bought a KZ trailer and so far I have welded the frame in four places, replaced the weak and bent axles, the broken springs, the wheel bearings and all the brake parts. When shopping for a trailer, start at the ground and work up, that pretty stuff is less important.
  • I completely agree with all of your points. We do love our pantry in our Kodiak 285 BHSL. But we hate the rounded dinette and the couch sucks. My wife seems to think that we can manage without the pantry, and use the other storage areas in the trailer. Our current TT only has about 1200# of CCC, so that might not be a big deal.
  • goducks10 above makes a good point.
    Our trailer has a GVWR of 10K and has 3150 lbs of CC.
    1220 lbs for CCC. for the Venture isn't much and can quickly get eaten up.
    You will really like the rear lounge floor plan. But I also noticed that there doesn't seem to be a pantry in the galley....strange for a 36 footer.
    Just things to think about.
    Good luck with your choice.
  • The items that stand out to me are the 8800 GVWR, 36' long and 1220 lbs for CCC.
