Camper_Jeff___K
Oct 05, 2023Navigator
VIDEO: 2000 F-250 Spare Tire Hoist Replacement
VIDEO 2000 F-250 Spare Tire Hoist Replacement VIDEO
2000 F 250 Spare Tire Hoist Replacement
An unnamed tire store in Quartzite is believed to be the culprit and cause behind the mystery of the missing spare tire. I purchased 2 new tires and had them installed on the rear. I also asked to take the better of the two tires and use that for a new spare tire. I got the tires installed fine. They have installed the wrong weight rating tires previously. The proper tires were installed this time after reminding the manager of the previous installation error. Though I inspected and cleared the new rear tires, it did not occur to me to check if the spare was changed. Now bear in mind, I have never had a flat and have never touched the spare tire. While I was replacing the muffler recently, another of my well over a hundred, How To Repair videos, I noticed there was no spare tire. I tried to imagine what happened and after many scenarios, I've concluded the tire shop employee doing the job did not know about the crank handle for the tire winch stored on top of the radiator. I am pretty sure the tire person used an air impact gun to lower and raise the tire. Upon raising the tire, the power of the air gun tightened the lift cable, compressed the tension spring, and pulled the cable out from the cable end. I was deliberately not told anything about the event and that my lift was broken, and I had no spare. This brings us back to my ongoing point, you need to be able to work on, and repair your own stuff, or else you're at the mercy of, and hoping for the honesty of others.
