- AnEv942NomadI also assume, other than support when converting to bed, there is no end support for table?
As much as table moves Id pull the hinge off and peen leaves tighter. Especially utility hinges, one of my pet peeves. Just gripes me, first thing before installing a hinges is to drag out drift and hammer to 'fix'. - Camper_Jeff___KNavigator
Kayteg1 wrote:
I had that kind of table in several RVs and boats and none required brace.
The floor mount was all it took.
That's the way S&S designed and built it. I can use the area open with no brace in the way. The brace makes for a solid table in use or when bumped. - Camper_Jeff___KNavigator
jimh425 wrote:
Seems like something else is wrong if it needs a hinge. At lasts most tables don't have them.
The brace flips down, drops 3/4" and becomes center support for the counter top when I convert the dinette area into a second bed. - Kayteg1Explorer III had that kind of table in several RVs and boats and none required brace.
The floor mount was all it took. - jimh406Explorer IIISeems like something else is wrong if it needs a hinge. At lasts most tables don't have them.
tuna fisher wrote:
Why a hinge?
When you take the post out, the brace flips down and becomes a center support for the table top when you turn the dinette table into a bed. - tuna_fisherExplorerWhy a hinge?
44,056 PostsLatest Activity: May 04, 2014
