otrfun
Jan 19, 2019Explorer II
Camper_Jeff_&_Kelli wrote:Agree. If you used 4ft of 6 gauge to the batteries and a short length of 8 gauge (less than 4 ft.) straight to the nearest ground point (mentioned in your first post), then, yup, you should be perfectly fine. That should be less than a .2v voltage drop (<1.5%) at 50 amps. Just fine. Most inverters will run fine down to 11 volts or so, so a .2v drop is not a concern.
600 watts needs 50 amps. The wire is rated 55 amps and is just under 4 feet long connected directly to the battery protected by a 40 amp fuse. What's the problem? I don't need bigger wire, Discount Solar confirmed that . . .
Camper_Jeff_&_Kelli wrote:Very true!
. . . Can't please everybody!
44,066 PostsLatest Activity: Jul 25, 2018
