I can not recommend any specific brand for LED lights.
Just replace the bulbs with the correct replacement LED light that fits the original socket. You will probably see that some 21W bulbs are now replaced with 1 or 1.5W. They use a lot less energy and create less heat. Note that there are very "cold" bulbs and "warmer" ones, meaning the light temperature - where cold means more blueish and around 5000K temperature, and warm means more yellowish at 3600-4000K temperature. Neither is better or worse, it depends on your personal preference. The warm light is more like the original incandescent bulbs.
