- sljkansasExplorerIRV2.com has a vintage camper section, I suggest you also make a post there.
- 69_AvionExplorerSome of the older campers have such unusual black water tanks that there are none available today. Pictures would help.
- recyclerExplorerlike 1971amerigo's camper my franklin's black tank was attached to the bottom of the toilet.. you may have to remove the floor from underneath to replace it..
- 1971amerigoExplorerOn my 71 Amerigo the black water tank is secured directly to the bottom of the toilet.Pics would help to see what you have for a setup.
I had to remove the toilet which revealed a closet flange which screwed through the floor into the top of the tank. - 67avionExplorer IIYou should post some pictures of the camper both outside and inside. If you can supply more information you may jog some memories. There is a lot of interest on this forum on restoring vintage campers. Best of luck.
- Golden_HVACExplorerTank-depot.com
THey sell all kinds of thanks, and some of the molds date back to the 60's. You might get lucky and find the right size tank, and they also sell fittings, and can put them just about anyplace you would need them on the tank.
Fred.
44,056 PostsLatest Activity: May 04, 2014
