slowleak's avatar
slowleak
Vintage Travel Trailer options?
I've been knocking around the idea lately of setting up a classic looking trailer with both the ability to haul swap meet items and antiques as well as provide me with a place to sleep and shower on the road.
I'd like to be able to haul this with nothing heavier than either my Lincoln Town Car or a small pickup or van.
I've found several trailers for cheap but most have severe roof or floor rot issues, the other day I stumbled on an older 21' or so long Airstream that's been all but gutted out, only the bathroom and bunk area remains, the kitchen, forward plumbing, and heater have been removed. Its roughly 40 years old and its cheap.
I also looked at a rather clean original Holiday Rambler circa the late 60's/ early 70's era that's appears to be in decent shape. Both are tandem axle models.
I realize there are limits to how much I can remove from an RV without weakening the wall or roof structure, the Airstream seems the best in this aspect. They also seem to be the least likely to leak and have major issues just by design.
Are there brands to stay away from? Any brands I should look for?
I was originally looking for something in the 16' range with one axle but those are out of sight price wise and I've yet to find one in decent enough shape in my price range.
Any suggestions as far as which brands are best for longevity?
Keep in mind that overall weight will also be an issue, my towing limits will likely be somewhere around a ton tops using my car, which no doubt will give the best mileage. I'm not hauling all that much weight in the camper, maybe an additional 300 to 500lbs or so max on top of the weight of a semi-gutted travel trailer.
  • We have a friend who goes to swapmeets in a toy hauler. He suggests that you weigh what you plan to take. Do not forget your weight, food. water amd clothes and probably a few other things. Your 500 pounds will add up very fast.
  • You have a lot of things to consider when looking for a trailer to fit our needs.
    You say hauling swap meet and antiques. What exactly are you hauling? 500lbs in weight will add up rather quickly.
    If you think you can pull only a ton of weight and that includes the extra 500lbs or so of product you are going to have a hard time filling your order.
    Not only the product you are carrying but also your fresh and blk/grey water will have to be considered.
    Good luck, keep us informed. I will be interested to see your trailer after the modifications
